many thanks Admin, but under the preferred network type there is no singular option for 4G.
What i have is 4G/3G/2G(auto), 3G/2G(auto), 2G
blackview_admin wrote:Hi there!
Go to Settings -> More -> Mobile Networks.
- Enable the "Advanced 4G LTE" setting.
- Under the "Preferred network type" setting, select "4G".
IF the 4G is available, your device will always stick to it.
If you device switches from different bands, it means that these bands are not always available (carrier's fault!)
The BV8000 PRO supports the VoLTE protocol, but it has to be available from you carrier and your cell service.
When active, the VoLTE icon will appear on the status bar.
