ameerah
[SOLVED] Wired headset problem
Wed Jan 17, 2018 12:14 am
The speakers attached to the device have been damaged, I bought another and first turned on the phone and the phone refused to recognize it and its connection sign does not appear at the top of the screen.
Re: Wired headset problem
Wed Jan 17, 2018 11:28 am
Hi there!
BV8000 Pro is equipped with a non-standard 3.5 jack port, so you'll have to buy headphones with a longer than normal head connector (or an adapter with the same feature).
Here you can buy Blackview original headphones:
https://www.aliexpress.com/item/New-Arr ... autifyAB=3
Refer to this threads for infos about an adapter:
viewtopic.php?f=191&t=168899
viewtopic.php?f=191&t=311088
