nonobike
[SOLVED] no notification since update 20180105
Mon Jan 15, 2018 5:47 pm
Hello.
since the update 20180105 I do not receive any notification (email, facebook ....).
I made a restore and a wipe but still the problem
Thank you for your help
CrazyWolf74
Re: no notification since update 20180105
Tue Jan 16, 2018 9:18 am
just have a look here : viewtopic.php?f=191&t=345022
regards
nonobike
Tue Jan 16, 2018 12:22 pm
duraspeed enabled ..
background task clear enabled ..
all applications whitelisted ..
but still no notification ...
jman0
Tue Jan 16, 2018 12:48 pm
That thread is not talking about duraspeed, but the background task clear feature. It seems like if you flash the latest upgrade, it's always on, even if you turn if off manually. So the solution seems to be setting it on and whitelisting all apps, just the same you did with duraspeed. And I guess you can then disable duraspeed again
Tue Jan 16, 2018 10:18 pm
Exactly.
I also suggest, for the moment, to FLASH your device to the 20171227 update.
