Thu Jan 11, 2018 3:11 pm
I just got the new BV9000 Pro, but I think there's a little problem. The slot containing the two Sim Cards seems to be missing one of the two pins/screws, which secure the slot itself to the "cap" outside (I can see two holes but one pin only), in fact, extracting it from its housing, fluctuates erratically. Could someone owning the same phone, check this particular, figuring out if it's an oversight, or the slot is really built like that?! Thanks a lot.
- SD Card Slot.jpg (279.06 KiB) Viewed 2294 times
