BJSr
OTA BV8000 V0.1_20170803_20180105-1104 results.
Wed Jan 10, 2018 1:13 pm
Old OTA was: BV8000 V0.1_20170803_20171011-0929
OTA updated to, now: BV8000 V0.1_20170803_20180105-1104
No factory reset.
Improved battery life/power.
Charged 4 days ago, Still 2 days left. Power saving Normal mode. At least a 50 % improvement with light use, 2 SIM cards.
--Update--- After 5 days since last charge, I was down to 8% remaining power on the battery, started a new charge; using APP Ampere I am getting a rapid charge rate of 2130mA. This is the same charge rate as before this OTA update.
If you are having problems with charging, use this App or similar to find the true values of the charge the battery takes.
Regards
Re: OTA BV8000 V0.1_20170803_20180105-1104 results.
Wed Jan 10, 2018 10:36 pm
Thanks for your feedback! ;)
Konservfabriken
Thu Jan 11, 2018 2:36 pm
When will V0.1_20170803_20180105-1104 be linked at ROM download?
And solves this update the problem with batteries who wont charge?
Thu Jan 11, 2018 5:16 pm
It will come soon!
Ralf-BV
Fri Feb 02, 2018 1:10 pm
Is there any known date for the firmware that will fix the background task problem? :?: :?:
Fri Feb 02, 2018 1:46 pm
Not for the moment.
Please don't go off-topic.
