Ced BV8000pro
[SOLVED] Can't connect USB with Win07 PC nor with bebop drone
Wed Jan 10, 2018 10:57 am
- I wanted to connect my BV8000pro with a windows 7 computer : nothing happened
- I wanted to connect my phone with a Bebop 2 Skycontroller 2 (drone controller) but nothing happened.
Do i need to upgrade phone's firmware ? (i made the phone upgrade, it is up to date at this time).
Are USB C-type OK to connect with devices ?
Re: Can't connect in USB with Win07 PC nor with bebop drone
Wed Jan 10, 2018 9:05 pm
Can you try to connect your phone to a WIN 8.1/10 System? Windows 7 is obsolete!
Does your controller support Android?
OTG is supported, and an OTG cable came with your device.
Ced BV8000pro
Wed Jan 10, 2018 9:34 pm
Well, tanks for your response, but there is something new :
I tryed with another USB-C cable (the Blackview original one), and all is fine, works perfectly.
Finally, the problem was that : i bought a bad USB-C cable, it doesn't works with the BV8000 pro...
Wed Jan 10, 2018 9:58 pm
Remember that the BV8000PRO is using a non-standard-lenght-USB-C-headed cable.
I'm closing this topic, as the problem is definitely solved. ;)
