patbell101
Cannot enter recovery mode
Tue Jan 09, 2018 11:00 am
I have an A7pro and after removing the battery (to insert the second sim) get told "password required after restart" I haven't set the password.
Tried Factory reset but when I get to the android robot where it says No Command, I hold vol+ and power and nothing happens except eventually it turns off. I never get any options to choose from.
Once i got a screen full of chinese but I can't get it again, it just turns off.
Re: Cannot enter recovery mode
Wed Apr 04, 2018 2:46 am
hello,
what's your firewarm version?
Did you update your device by flashing or by OTA update?
Did you perform a factory reset after the update?
