communicator
[SOLVED] automatic answer with an motorcycle intercom
Sun Jan 07, 2018 2:23 pm
I have a Blackview BV8000 Pro for a few months and that works perfectly (Thank you Blackview).
When I drive my bike my BV8000 Pro is connected in bluetooth with a intercomm SENA 10C Bluetooth headset.
The problem is that when I receive a phone call, the phone does not pick up automatically after several rings.
Is there a setting to make the phone take the call after 2 or 3 rings?
In advance, thank you for your answer
Re: automatic answer with an motorcycle intercom
Sun Jan 07, 2018 11:09 pm
This option doens't seem to be implemented in Android 7.0, but you can work around the problem by installing a third party app from the play store ;)
