sticzu
Re: [TRACKED] Background task clear always on (also if switched off) after OTA update 20180105-1104
Mon Jan 08, 2018 8:07 am
Someone else have problems without durasped? Each time after unlocked phone i have to turn on Kaspersky , Messenger and other apps. Its closing them. I did factory reset after update but its dumb idea to made factory reset after each patch
tavas
Re: Background task clear always on (but switched off) after OTA update 20180105-1104
Mon Jan 08, 2018 5:46 pm
blackview_admin wrote:
A factory reset after each update is highly recommended, practically mandatory to avoid strange issues. A firmware update, if your phone works as it should, isn't mandatory by the way ;)
I guess that you haven't performed a factory reset after the latest update, right?
My phone does crash every now and then. And have to admit, to my taste none of the mobile devices ever work as they shoud :-)
No, haven't done factory reset.
Mike!
Mon Jan 08, 2018 6:29 pm
Did you read the first post in this thread? Seems you have the same problem and it has nothing to do with DuraSpeed as DuraSpeed does not kill background tasks nor prevents them from being killed. Please read my workaround, it should work for you, too.
cientistagyn
Mon Jan 08, 2018 9:50 pm
FINALLY AN UPDATE THAT BRINGS HDR TO MY REAR CAMERA
NOW THAT'S FINE !!
THANK YOU BLACKVIEW !!
sticzu
Tue Jan 09, 2018 12:48 pm
i didnt, i did what You wrote, thanks. its ok now.
can You help me with widgets? when i install any weather app it shoudl be possible to take out widget to screen (like callendar, clock etc)
i dont see it in available widgets.
Mike!
Tue Jan 09, 2018 5:14 pm
For the widgets to work you have to install the app to internal memory, not SD card. But that's off topic here ;)
sticzu
Tue Jan 09, 2018 6:10 pm
I dont have sd card in :)
add
ok, problem solved. i've had to install almost 15 different apps to find one whitchone is working
papapedrox
Tue Jan 09, 2018 10:53 pm
Which one?
sticzu
Wed Jan 10, 2018 7:47 am
This one
Wed Jan 10, 2018 12:10 pm
Guys, please, don't go off-topic.
If you want to talk about other issues, please open new dedicated threads ;)
