nsansilva
[SOLVED] unable to upgrade to last version of firmware
Fri Jan 05, 2018 2:12 pm
My BV8000Pro stay on the firmware BV8000Pro-Blackview-V0.1_20170803_20171011-0929, i tried make Local updates to version BV8000Pro_blackview_20171219 according to the procedure available on the link: viewtopic.php?f=192&t=213272
- Local Update: Save ZIP-File to your phone storage and select it at "Settings>About phone>Wireless Update>...-Menu>Local updates"., and don´t work.
How can i make the update to last version of firmware?
I tried to make OTA updates and appear the information: Your device's software is currently up to date.
Model Number: BV8000Pro
Android Version: 7.0
Android security patch level: July5, 2017
GSM Baseband version: MOLY.LR11.W1630.MD.MP.V14.P14, 2017/07/31 14:41
CDMA Baseband version: SIXTH.CBP.MD.MP5.V19_P5, 2017/07/31 15:03
Kernel version: 4.4.15 root@yz-All-Series #2 Wed Oct 11 09:33:00 CST 2017
Build number: BV8000Pro-Blackview-V0.1_20170803
Wait return more fasted possible.
Tnx,
Natanael dos Santos.
Re: Don´t upgrade to last version of firmware
Sat Jan 06, 2018 10:12 pm
Unfortunately local update is getting some problems on latest firmware versions.
Please update your device by flashing the latest firmware.
How to flash tutorial:
viewtopic.php?f=192&t=319505
Firmware download page:
nsansilva
Re: [SOLVED] unable to upgrade to last version of firmware
Mon Jan 08, 2018 7:49 pm
Tnx for your return, i get the update by OTA and my version is BV8000Pro-Blackview-v0.1_20170803_20180105-1104, but when i make another check for updates appear the error: Network connection failed (java.security.cert.CertPathValidatorException: Trust anchor for certification path not found.)
Regards,
Natanael
Wed Jan 10, 2018 10:16 am
The final solution will be flashing your device to the latest firmware, but before that you can try to perform a factory reset and then start the OTA update again. ;)
