spit_fox
[SOLVED] Update 20171227-1550 - Battery Drain again?
Thu Jan 04, 2018 1:29 pm
Hi All,
I've just updated via Wireless to 20171227-1550.
I don't see this firmware in the Download section, and I'm afraid to go back to the old 20171219.
What's is new with this new firmware?
It seems the battery is draining quickly again.
Thanks.
George SPiT
Re: QUESTION: Update 20171227-1550 - Battery Drain again?
Thu Jan 04, 2018 11:09 pm
Did you perform a FACTORY RESET after the update? ;)
Whip85
Fri Jan 05, 2018 7:06 am
Definitely no battery drain. I did however pick up that with the Bluetooth settings not optimized mobile standby pops up under the battery usage with a higher percentage as the screen usage but when all the settings are optimised then it doesn't reflect under the usage. I haven't seen a big difference maybe 2% to 5% between the two. Anyone else notice that?
Fri Jan 05, 2018 11:43 am
I think this is normal ;)
ipollen
Sat Jan 06, 2018 6:27 pm
I am also experiencing battery drain again under 20171227 Yes I did perform a factory reset after flashing.
Ian
Sat Jan 06, 2018 10:08 pm
Anybody else?
Rgaspar
Sat Jan 06, 2018 10:28 pm
not quite a battery drain but a abnormal battery consumtion
Sat Jan 06, 2018 10:32 pm
Did you perform a factory reset after the OTA update, guys?
ipollen
Sun Jan 07, 2018 9:32 am
Yes definitely did a factory reset. Phone lost 25% overnight.
Ian
Sun Jan 07, 2018 9:48 am
Ok, i'm sending this infos to the tech team. Let's start again :lol:
