Daniel1978
[SOLVED] Fingerprint is very hot
Tue Jan 02, 2018 10:59 am
Hello there, i am very sad, because two days ago the fingerprint of my blackview vb8000 is very hot and it burns in my hands. I have been restored the factory settings, but isn't work. can you help my? thanks
Re: Fingerprint is very hot
Tue Jan 02, 2018 7:38 pm
Unfortunately, this is an hardware fault.
You'll have to contact your seller for a replacement/repair under warranty.
If you are handy and don't care about warranty (wich will be void!) you can replace it by yourself:
https://www.aliexpress.com/item/Blackvi ... autifyAB=0
ozmo
Re: [SOLVED] Fingerprint is very hot
Wed Jan 03, 2018 11:18 pm
How did you solved your problem?
Thu Jan 04, 2018 10:15 pm
Just read my previous post...
