justgenius
[SOLVED] ROM Version Number not updating
Mon Jan 01, 2018 6:34 pm
I have applied the following updates on my BV8000 Pro:
1. BV8000Pro_blackview_20171011 (OTA)
2. BV8000Pro_blackview_20171114 (Local install)
3. BV8000Pro_blackview_20171219 (Local install)
However, when I look at the phone Settings, under Wireless Update, it shows current version as: BV8000Pro-Blackview-V0.1_20170803_20171011-0929.
Why does it not show the updated version number from the updates #2 and #3 above? It seems to only update the version number from the last OTA update. How can I check to see if the updates #2 and #3 above have actually been applied correctly?
Re: ROM Version Number not updating
Mon Jan 01, 2018 8:49 pm
Local installation is not working with the provided files (this is why your current version is still the 20171011 one) .
To get the latest firmware, you can choose between waiting for the OTA update or going to the flashing route ;)
Users browsing this forum: WeraziMUH and 2 guests
