HNWeb
[SOLVED] Disable sos key
Sat Dec 30, 2017 9:58 pm
In this http://bbs.blackview.hk/viewtopic.php?f=191&t=320609&start=14 Blackview_admin promised that in 20171219 firmware I can to disable the SOS key, How can I do that?
Thanks
Re: Disable sos key
Sat Dec 30, 2017 10:04 pm
You will find the option under the settings tab. ;)
ozolli
Re: Disable sos key
Sat Dec 30, 2017 10:13 pm
