ozolli
[SOLVED] OTA update file
Sat Dec 30, 2017 6:54 pm
Where is the OTA update file downloaded and what is its name ?
Re: OTA update file
Sat Dec 30, 2017 9:18 pm
Sorry but i really can't understand your question. :roll:
ozolli
Re: OTA update file
Sat Dec 30, 2017 9:31 pm
When there is an OTA update available you download the update file using the settings update utility. This file is then saved somewhere on the phone and applied after reboot in recovery mode.
I would like to know where this file is saved and its name.
On some phones it is saved in the /cache folder and named update.zip but this is not the case on the BV8000. This is why I ask ;)
Re: OTA update file
Sat Dec 30, 2017 9:33 pm
What's the reason behind this question? ;) what you want to do?
ozolli
Re: OTA update file
Sat Dec 30, 2017 9:44 pm
See what has changed before applying the update.
Doing a factory reset and all the work needed thereafter (installing all apps ans setting them) is time consuming so I'd like to see if this is worth it.
Re: OTA update file
Sat Dec 30, 2017 9:53 pm
You don't have to apply the update as soon as it reaches you. Just wait a bit for the official changelog or for some users feedback on the forums and you'll be ok ;)
ozolli
Re: OTA update file
Sat Dec 30, 2017 9:55 pm
Yeah I know, I know... But I'm curious and like to do things by myself and not wait for others instead :)
Users browsing this forum: Google Adsense [Bot] and 2 guests
