metal_meltdown
[SOLVED] 29122017 update
Sat Dec 30, 2017 4:38 pm
hello, I performed the last update of December 29, but I report that the adaptive brightness no longer works (the screen remains always on the same intensity) and also the proximity sensor does not work during calls. Is it possible to solve the problem manually or do I have to wait for a new fix? thank you.
Re: 29122017 update
Sat Dec 30, 2017 4:51 pm
Please perform a factory reset and report back.
metal_meltdown
Re: 29122017 update
Sun Dec 31, 2017 4:18 pm
I preferred not to do the hard reset, but turn off the phone all night and switch it on again in the morning. The problems described above seem to be resolved.
Re: 29122017 update
Mon Jan 01, 2018 2:49 pm
Keep in mind that not performing a factory reset after each firmware update can create unexpected issues :geek:
metal_meltdown
Re: 29122017 update
Mon Jan 01, 2018 8:55 pm
I did not do the factory reset because I thought it would bring the phone back to its original state that came out of the factory, then delete the last update made, sorry
Re: 29122017 update
Mon Jan 01, 2018 8:59 pm
Now you know it ;)
