coonrado
Re: [TRACKED] Local ROM update not working
Mon Sep 03, 2018 11:14 am
VADUS wrote:
Thanks again, I've done flashing downgrade + local update to 8.0, and now everything is working great! Looks much faster, than it was on 7.0.
I have the same problem, which ROM version did you install first?
VADUS
Mon Sep 03, 2018 2:49 pm
First I flashed it to 20171219, and then installed local update. But now, I DO NOT recommend you to upgrade on 8.0 - there is too much bugs in this software, especially with the battery drain. Wait for a next software release.
mkhakk
Wed Oct 17, 2018 5:54 am
I also do not encourage to update to android 8, I had to do a downgrade because I could not get root access with android 8, since I need it to have free internet, and I will not sacrifice that just to have android 8 ..
