Chris_2017
[TRACKED] Local ROM update not working
Tue Dec 26, 2017 5:38 pm
Hi guys,
Just downloaded latest ROM: BV8000Pro_blackview_20171219
I did a local update, the phone seemingly updated. When it rebooted I checked my current version and it's still V0.1_20170803_20171011-0929
How can I get the phone to update properly?
Chris
Re: Local ROM update not working
Tue Dec 26, 2017 7:53 pm
You'll have to flash it to the latest firmware.
Follow this tutorial:
viewtopic.php?f=192&t=319505
Chris_2017
Thu Dec 28, 2017 1:15 pm
Not cool, I don't have time to play a technician. Even if I flashed as advised what about next updates? Will I have to do it this way every time and wipe phone in the process? This is not comfortable.
Thu Dec 28, 2017 8:49 pm
A phone wipe (aka factory reset) is highly recommended after each update, OTA, local or flashed.
This is a good practice on all the Android phones if you want to avoid issues and to use firmware updates correctly. ;)
Next updates, as always, can also come via OTA, so in this case you won't have to flash your device everytime.
Chris_2017
Fri Dec 29, 2017 11:16 am
Yeah, I can live with a wipe as Google has all my stuff synced but the thing with the complicated PC application and a danger of bricking my device is a bit deterring. On the other hand its great that you guys release new ROMS so quickly I will wait a few more weeks and when time allows, will do the flashing.
Cheers,
Chris
Fri Dec 29, 2017 8:53 pm
Cheers,
Chris
If you need any help, we are here ;)
Chris_2017
Re: [SOLVED] Local ROM update not working
Sat Dec 30, 2017 10:36 am
Awesome, it's nice to know I can count on you guys!
mambociccio
Fri Jan 05, 2018 11:22 am
Good Morning
You know an app for backup all apps and restore them after the wipe factory reset?
Fri Jan 05, 2018 11:36 am
mambociccio wrote:
Good Morning
The google android stock backup should provide that
kavedel
Sat Jan 06, 2018 8:03 am
About the backup you are talking about. Is there a backup app that keeps all the apk files so you don't have to download them all from the start? And restore them back?
Users browsing this forum: No registered users and 10 guests
