worldeater
[SOLVED] Led light doesn't switch off + localisation issue + accessories
Mon Dec 25, 2017 5:39 pm
Hi to all!
Got a BV8000 Pro a few days ago, and I already have a few issues with it.
1 - Led light doesn't switch off after charging. Whether it's red or green: when I unplug the cable, the led stays on.
I have to reboot the phone to switch it off.
2 - When I put the phone on Airplane mode, and then turn this mode off, the GPS localisation doesn't work for an hour. Rebooting the phone doesn't help.
3 - I can't plug any regular jack port to the phone (speakers, headphones), as the gap is longer. Where can I buy an adaptor?
Same depth issue with the USB-C cable. Where can I buy an extra cable?
Thank you very much for your help!
And Merry Christmas too all the Team :)
Re: Led light doesn't switch off + localisation issue + accessories
Tue Dec 26, 2017 3:08 pm
1 and 2) Your problems look uncommon. I suggest to update your device to the latest firmware (20171219) and then perform a factory reset.
3) Here you go!
https://www.aliexpress.com/item/New-Arr ... eLevelAB=5
worldeater
Sun Dec 31, 2017 2:04 pm
Okay thank you!
I'll try that and let you know of the problem persists.
Cheers :)
