Dolly893
[SOLVED] Fingerprint sensor gets hot and drains battery
Mon Dec 25, 2017 12:39 pm
As stated in title , the sensor gets really hot while having the screen on and charching. Its almost tot hot topic touch! Please contact me for fix or anything.
Greetings, Johan.
Re: Fingerprint sensor gets hot and drains battery
Tue Dec 26, 2017 2:58 pm
It really looks like an hardware fault, but before sending your device back to your seller for a replacement, update it to the latest firmware (20171219) and then perform a factory reset. Once done these steps, report back!
Dolly893
Re: [SOLVED] Fingerprint sensor gets hot and drains battery
Wed Jan 24, 2018 5:11 pm
Hell of al late reply but i Just disconected the sensor in al there was An Tiny little dent in the plate,
Wed Jan 24, 2018 9:59 pm
Thanks for reporting back anyway ;)
PurpleJack
Mon Mar 05, 2018 12:07 pm
My phone has the same problem.
I have installed latest updates (20170803) and done a factory reset but the problem continues.
The phone was working well until a few days ago.
How can I fix this problem? Is the phone safe to use ?
Looking forward to a reply because I really like this phone.
Mon Mar 05, 2018 10:18 pm
Hi there!
Unfortunately your fingerprint sensor got an hardware fault and needs to be replaced.
I suggest to contact your seller to have your device replaced under warranty as soon as possible.
