Zetri
[SOLVED] BV8000Pro Can not do factory reset (no command)
Fri Dec 22, 2017 9:11 pm
Dear Admin,
Kindly please help:
1. I can not do factory reset, respond on VolumeUp+Power button pressed was a "no command"
2. BV8000Pro key board, first row of 1234567890 and second row of qwertyuiop was not responding.
Howeer, third row of asdfghjkl and fourth row of zxcvbnm
When button character button pressed, same.
First row of 1234567890 was not responding.
However, rest of first row was not responding.
3. Does this BV 8000 Pro support 4G LTE band in Indonesia.
For your kind prompt assistance please.
I saw the value of this device, it is a pity that I can not use it now.
Thank you,
Best Regards,
Zetri
Re: BV8000Pro Can not do factory reset (no command)
Sat Dec 23, 2017 2:38 pm
Hi dear!
1) Please follow this tutorial to boot your device into recovery mode (and then perform a factory reset)
viewtopic.php?f=192&t=334922
2) Very uncommon problem. I suggest you to update your device to the latest firmware and perform a factory reset. This should solve your issue.
viewtopic.php?f=192&t=319505
viewtopic.php?f=192&t=213272
3) Your device supports 4G LTE frequencies 700 /800 /850 /1700 /1800 /1900 / 2100 / 2600 / TDD 1900 /2300 /2600 /2600 / CDMA 2000 Mhz.
In indonesia, as far as i know, some carriers support the 1800 Mhz frequency. If your carrier is one of them, you'll enjoy the LTE.
Zetri
Re: [SOLVED] BV8000Pro Can not do factory reset (no command)
Wed Jan 03, 2018 3:00 pm
Dear Admin,
Am trying to do the flashing tonight.
Alternatively, would replace the touch screen would solve the problem?
If yes, please advise the brand and model number so that I can source it accordingly.
Best Regards, Zetri
Thu Jan 04, 2018 9:52 pm
Best Regards, Zetri
Hi there!
You can find the display + touchscreen unit here:
https://www.aliexpress.com/wholesale?ca ... 00+pro+lcd
You can try to replace it, but remember that repairing it by yourself may void your warranty.
I suggest to contact your seller before attempting to do that.
