faiche
LED low battery e more
Fri Dec 22, 2017 9:24 am
hi, I can not remove the red LED of the low battery, it is too powerful and annoying, how can I remove it?
In addition to this another fstidiosa thing and the music at the start, how can I remove it?
I can not root my smartphone, which would have allowed me with some application to change these settings. A tip for developers is to insert special menus for these removals of future updates. thanks a lot of
translate by google
Re: LED low battery e more
Mon Apr 23, 2018 3:31 pm
Hi!
1) Low battery led can't be disabled.
2) To mute the boot jingle, just set your phone into silent/vibration mode. In this mode, if you restart it, the boot jingle will be silenced.
