sousa125
[SOLVED] phone don´t work
Thu Dec 21, 2017 1:57 pm
hello..
My cell phone was on when I put it on charging during the night.
In the morning when I picked it up it was off.
Now I try to start and it does not start. remain off.
When I put it on charging, there's a red light on the front.
help please
Re: phone don´t work
Thu Dec 21, 2017 10:21 pm
Are you using the original charger and cable? Can you try another charger and a microusb cable equipped with our microusb/USB-C adapter?
sousa125
Thu Dec 21, 2017 11:39 pm
Yes i using The original charger, and i try with another diferent way.
jman0
Fri Dec 22, 2017 7:17 am
Red light means it's charging. Anyway, try different chargers and cables
sousa125
Fri Dec 22, 2017 10:49 am
already tested with other forms of loading, and nothing
Sat Dec 23, 2017 2:52 pm
Plug your device into a charger and reboot it to recovery mode. Then perform a factory reset.
Follow this tutorial: viewtopic.php?f=192&t=334922
If your device doesn't allow you to do that, it is faulty. In this case you'll have to contact your seller for a replacement.
