Don Harry
UPDATE 20171219
Wed Dec 20, 2017 6:55 pm
UPDATE 20171219 availible
Update failed to install - i tried 3 times.
ozolli
Re: UPDATE 20171219
Wed Dec 20, 2017 7:24 pm
Update worked for me.
The only change I noticed is a new "Multifunction key" setting which can disable the SOS button.
Same kernel, GSM and CDMA as the 20171114.
Edit: A lot of applications failed to start with this update. I rolled back to the previous one.
DevilDaxter
Re: UPDATE 20171219
Wed Dec 20, 2017 9:38 pm
Admin please upload this version on Forum :)
HacXander
Re: UPDATE 20171219
Thu Dec 21, 2017 12:06 am
How did you roll back to a previous update?
I read somewhere on this forum that if you do that it will brick your phone.
Whip85
BV8000Pro_blackview_20171219
Thu Dec 21, 2017 3:44 pm
When can we expect the OTA update?
Re: BV8000Pro_blackview_20171219
Thu Dec 21, 2017 9:41 pm
When it will (or if it will) come :D
By the way, the flashing file is already available:
viewtopic.php?f=192&t=213272
Re: UPDATE 20171219
Thu Dec 21, 2017 10:16 pm
The 20171219 file is already available for flashing.
You can roll back to the 20171114 version, but not to older versions.
Re: UPDATE 20171219
Thu Dec 21, 2017 10:22 pm
Remember to perform a FACTORY RESET after each firmware update!
ozolli
Re: UPDATE 20171219
Fri Dec 22, 2017 12:22 am
The factory reset was done, as always ;)
Whip85
Re: UPDATE 20171219
Fri Dec 22, 2017 6:46 am
I tried to do it via local update followed by a factory reset but it still shows the firmware I had. BV8000Pro-Blackview-V0.1_20170803_20171011-0929
