michaelp42
[CLOSED] Battery drain
Tue Dec 19, 2017 6:53 pm
I've had my BV8000 for nearly a week, and I like everything about it, except the battery drain when the device is on standby.
With no apps open, and the phone used only to check battery level, its used 5% in under an hour since I unplugged the charge cable. I've updated to the latest official firmware.
I'd really rather like to keep the phone, but with the excessive battery drain, I fear I'll have to send it back. Is there a solution?
Re: Battery drain
Tue Dec 19, 2017 9:34 pm
The issue is being studied by our tech team. Refer to this thread:
viewtopic.php?f=191&t=329113
If you don't want to wait for a fix, you can ask your seller for a replacement ;)
