Whip85
[SOLVED] How to update to 20171114
Thu Dec 14, 2017 3:06 pm
Can you do this update via local update or only by flashing it?
ozolli
Re: BV8000Pro_blackview_20171114
Thu Dec 14, 2017 4:23 pm
For me it was an OTA update.
Thu Dec 14, 2017 5:34 pm
This firmware is already available:
viewtopic.php?f=192&t=213272
Just do what you prefer ;)
Whip85
Re: [SOLVED] BV8000Pro_blackview_20171114
Thu Dec 14, 2017 6:55 pm
I tried doing it via local update as I don't feel comfortable doing a flash but it didn't update my firmware and it isn't available on OTA for me yet. Am I perhaps doing something wrong? :roll:
jman0
Fri Dec 15, 2017 7:13 am
A lot of us didn't get it via OTA. That's why I finally decided to flash it via SP Flash Tool
Whip85
Fri Dec 15, 2017 9:22 am
Admin will we still receive the OTA update or do you have any suggestion regarding the local update apart from doing a flash of the rom?
Fri Dec 15, 2017 7:38 pm
OTA update should come, but if you don`t want to wait, go to the flashing route! ;)
Whip85
Fri Dec 15, 2017 7:51 pm
Thank you I will patiently wait for the OTA update. 8-)
Dustyman042004
Won't update to new update
Sat Dec 16, 2017 2:36 am
I went to update local update to newest version posted about bv8000 pro that post the warning about the flashing saying u can't go back after flashing and says installing but when it reboots it does not show as the current version that I downloaded. I even factory reset and tried. Still no luck why is this happening
Re: Won't update to new update
Sat Dec 16, 2017 12:09 pm
Can you post a screenshot of the version after the update?
