SNap1992
[SOLVED] Blackview BV800 Pro headphones URGENT!!!
Thu Dec 14, 2017 10:41 am
Hi all,
could someone please give me a link from where I can buy a headset/headphones for my BV800 PRO.
Connectors also work.
Please only give links to either aliexpress or gearbest since I cannot order from amazon or ebay.
Thanks a lot!
Re: Blackview BV800 Pro headphones URGENT!!!
Thu Dec 14, 2017 11:47 am
Aeron
Re: [SOLVED] Blackview BV800 Pro headphones URGENT!!!
Fri Dec 15, 2017 8:50 am
If you want to be able to use any headphones, you could use this adapter.
