jman0
[SOLVED] Issues found on the new 1114 firmware
Thu Dec 14, 2017 7:25 am
Hi.
After two days with the new 1114 version, which corrects the camera bugs, I've found these issues, which I didn't have on previous firmwares:
1) Sometimes (but not always) when I turn Bluetooth on, the Bluetooh sharing app force closes, and keeps force closing in a loop, no matter what I do, and only a reboot will fix it. After the reboot, BT works as expected, but a few hours later, it may start again. I tried disabling battery optimization for BT sharing app, but it didn't fix the issue.
2) Wifi is less stable. On previous firmwares, wifi, at least in my case, was rock solid, even at quite a distance from the router, but now I have to keep closer for it to work and have good signal, and I loose connection in places where I had a stable connection before.
All the rest is working like before. I've had around 5% battery drain overnight, in around 7 hours, which, as always, is a lot for a 4000maH battery phone.My previous phone, an Elephone P8000, with a similar battery capacity, would loose just 2-3% during a similar period.
Re: Issues found on the new 1114 firmware
Thu Dec 14, 2017 11:53 am
Can anyone else confirm this issues or other issues?
How's the camera working?
jman0
Thu Dec 14, 2017 2:11 pm
The camera works well
Thu Dec 14, 2017 6:02 pm
Did you perform a factory reset after the firmware update?
jman0
Fri Dec 15, 2017 7:15 am
I flashed it via SP Flash Tool and chose to flash everything, userdata included. So yes, I did
Fri Dec 15, 2017 7:49 pm
i'm waiting for other users to report the same problems (if they have them), so i can track this issue properly.
