zoli70
Touch problem
Tue Dec 12, 2017 6:28 pm
1st. I bought a P2 device from Tinydeal and it came without sim card tray.
2nd. The touchscreen is not enough sensitive all over the phone. The bigger problem is if I'd like to write a message the "y" or if I change "z" is not working on the screen. How can I solve this problem?
Thanks
Re: Touch problem
Tue Dec 12, 2017 9:36 pm
zoli70 wrote:
Thanks
Hi zoli70,
both of the issues sound like you received a badly repaired or defective device. I suggest you return it to the dealer.
You could additionally try a test mode where you can test your screen following a previous post: http://bbs.blackview.hk/viewtopic.php?f=171&t=329921#p595307. Just look for the screen tests there.
zoli70
Re: Touch problem
Wed Dec 13, 2017 2:58 pm
Thanks for the answer. I did the screen test and the result was sad. You see in the pictures.
Re: Touch problem
Wed Dec 13, 2017 9:16 pm
zoli70 wrote:
Hello zoli70,
thank you very much for the pictures. Indeed this shows that your device is defective. I feel sorry that you got disappointed.
Hope you get the refund from Tinydeal.
