ayirus89
[SOLVED] Mobile stuck in Bootloop after Factory Reset
Tue Dec 12, 2017 5:33 am
I tried to factory reset my mobile after which my mobile is stuck in bootloop (it switches On & TWRP recovery is opened). I couldn't boot to system. Pls help.
Re: Mobile stuck in Bootloop after Factory Reset
Tue Dec 12, 2017 10:24 am
Please restore the stock recovery. Otherwise i can't help you.
