Hi everyone,
I'm a BV8000 Pro user and has been using it since September 2017. Everything worked fine until last night my BV8000 has charging problem. Everytime I charge it, the battery indicator show charging process but the percentage doesnt't increase, still stuck on 25% (even decrease until left 20% at the time I write this post.)
1. My BV8000 is in standard ROM, always update firmware. Last firmware on my BV8000 Pro is BV8000Pro-Blackview-V0.1_20170803_20171011-0929.
2. I have change the C-usb cable with another original Blackview C-usb cable (I have spare cable), problem still persist.
3. I've tried to charge using another charger (non-blackview) with 9V-2A output, still no change.
4. Charged using 3.0 usb port in my Laptop, problem still persist.
What else should I do? Any advice before my phone run out of battery.
Thank you.
