Tiago
[SOLVED] Camera Focus
Mon Dec 11, 2017 9:53 pm
Hi, good afternoon.
The focus of the BV 8000Pro camera is not working correctly closely, letters get blurred, since the Bv7000Pro works perfectly. I tried to set autofocus, manual focus, it can not fix the sharp lyrics.
Re: Camera Focus
Mon Dec 11, 2017 11:03 pm
This problem has been fixed by a firmware update long time ago. Please update your device to the latest firmware and then perform a factory reset.
