federicoiovanovich
[SOLVED] BV8000 Pro CHARGING PROBLEM / DOESN'T CHARGE
Mon Dec 11, 2017 12:15 pm
Hi There!
I have a big problem right now: My BV8000 Pro won't charging anymore.
I'm charging the phone with the original cable and charger but the battery icon is on 0% from hours and doesn't charge.
The phone is shutted down and won't switch on. I've tried also connecting to the usb port of my computer but the problem persists.
I've tried to reboot the system following this topic:
viewtopic.php?f=192&t=334922&hilit=bv8000+pro+reboot
but nothing, the problem persists.
The Factory Reset could solve the problem? I don't want to miss all my files, It will be another big problem for me.
Please help me, I need the phone back working urgently!
Thank you so much for the support,
Cheers!
Re: BV8000 Pro CHARGING PROBLEM / DOESN'T CHARGE
Mon Dec 11, 2017 10:59 pm
Hi there,
it really looks like a bad hardware fault. Unfortunately your only solution is to contact your seller for a replacement.
The only thing you can try before sending it back is to charge your device using another cable + the micro-usb/USB-C adapter.
This will exclude a cable fault.
