sticzu
magnetic cable / ali express
Mon Dec 11, 2017 1:31 am
hi
did someone bought a magnetic cable for 8000pro on aliexpress?
it has to be longer then normal, i cant find nothing.
maybe someone have correct cable/adapter and can paste link in answer
thanks
(sorry for english if something wrong)
ozolli
Re: magnetic cable / ali express
Wed Dec 13, 2017 2:07 pm
I've read that this one: https://www.gearbest.com/chargers-cable ... tml?wid=55
is okay. Maybe trimming a bit of the white rubber on the Type C end could help if it doesn't fit out of the box.
BJSr
Wed Dec 13, 2017 2:19 pm
Hi.
Like most other non BV8000 USB-C connectors, you should be able to modify the end(by trimming off insulation by 2mm). Have done it many times mostly with success.
Regards
sticzu
Wed Dec 13, 2017 9:41 pm
ok, i'll order this one. w'll see if it works :)
