Paul
[SOLVED] SMS to MMS conversion
Fri Dec 08, 2017 9:46 am
Could you help me with the following issue ? Please
Issue : auto conversion of long text message or SMS to MMS.
When I write a long text message/SMS (when the number of caracters exceed 3 sms), my SMS is converted in MMS. I have an automatic infobull appears on my screen "Converting to multimedia message...".
If it can help :
- I counted, the first sms has 160 caracters, the second : 63 caracters and the third : 66 caracters.
- Above the green arrow to send the text message, I have something like a counter wich shows number of caracter on the number of text message, just like this : 63/3.
Thanks in advance,
Regards,
Re: SMS to MMS conversion
Fri Dec 08, 2017 2:21 pm
Hi there! This is not an issue, much less Blackview's one, but a "feature" of the stock Android SMS/MMS messages app.
There is not solution to that apart using a 3rd party SMS/MMS messages app that, by the way, you can easily find on the Play store.
Paul
Re: [SOLVED] SMS to MMS conversion
Fri Dec 08, 2017 7:05 pm
Thanks for your fast answer.
It's too bad. It's a bit annoying.
