Tom77
[SOLVED] Batterie charging issue
Fri Dec 08, 2017 8:37 am
Hi all,
I've an issue with my BV8000PRO when I want to charge the batterie: when I'm connecting charger to USB C port, message "Batterie charging" appears for 1 seconde then immediately disappears. Same issue if I'm connecting the phone to laptop USB port throw USB cable.
However, after a reboot, batterie charging is possible...incomprehensible, and to be honest, reboot the phone each time is not so convenient and user friendly...
Any idea?
Thanks a lot for your help and advice
Re: Batterie charging issue
Fri Dec 08, 2017 8:45 am
Are you using the original cable and charger?
Tom77
Fri Dec 08, 2017 8:57 am
Yes, I confirm that i'm using BV original charger and cable.
Fri Dec 08, 2017 2:28 pm
Can you please use your microUSB/USB-C adapter to charge your phone? I need to know if the original USB-C cable is faulty.
Tom77
Mon Dec 11, 2017 9:19 am
I use the microUSB/USB-C adpater provided in the Blackview package with 2 of my personnal USB cables => same issue (batterie charging for 1 seconde then stop).
Thank you for your support.
Mon Dec 11, 2017 11:02 pm
Ok, from what i can see this really looks like an hardware fault. Please contact your seller for a replacement under warrany. I'm sorry for that.
