wade3
[SOLVED] Wifi problems
Mon Dec 04, 2017 11:37 am
Since OTA update if I leave one wifi field and go into another I need to reboot for it to connect.... Very frustrating and a total waste of my time. This is the sort of thing that makes me want to buy another phone. I had been very happy with it until now. Please can you fix asap? My current is 20171011-0209 and I am told no other update are available. I will be reluctant to do updates in future once I have a stable version as the last one was fine. I cannot go more than a few days with this annoying wifi problem
Also I has a problem posting on this site - I made three feedback suggestions under a different user - none of which appeared. I have signed up using in different name in the 'hope' this will improve my lot.
Re: Wifi problems
Tue Dec 05, 2017 11:10 am
Hi! Sorry about the moderation queue, we are working on it. It will get better! ;)
Considering that your problem is quite uncommon.. did you perform a factory reset after the firmware update? This is HIGHLY recommended.
