BJSr
[CLOSED] USB C OTG RJ45 Ethernet Adapter
Thu Nov 30, 2017 10:12 am
One question: On my BV8000, will I be able to connect to LAN using an USB C OTG RJ45 Ethernet Adapter, dongle?
Regards
Re: USB C OTG RJ45 Ethernet Adapter
Thu Nov 30, 2017 10:33 am
Considering that not all the adapters are compatible with every android device, you'll have to buy it (i reccomend a seller wich accepts returns) and try.
Once bought, before connecting it, rember to switch off the wifi and the SIM data connection.
BJSr
Re: [SOLVED] USB C OTG RJ45 Ethernet Adapter
Tue Dec 05, 2017 8:45 am
Hi.
Current ROM:
BV8000 V0.1_20170803_20171011-0929
The Ethernet LAN part, does not work on BV8000 PRO, this function is not enabled. Tried this adapter on a Samsung Galaxy A5 (2017) running Android 7.0. It worked as it should.
Can you give me advice on how to enable Ethernet (Eth0) in BV8000, and include this in the next ROM update.
Kind regards
Tue Dec 05, 2017 10:58 am
BJSr wrote:
Hi.
Current ROM:
Kind regards
Did you disable WIFI and SIM data connection before plugging in your adapter? can you try another adapter on your BV8000 just to be sure?
Anyway, i will forward this request to our tech team! ;)
BJSr
Re: [TRACKED] USB C OTG RJ45 Ethernet Adapter
Tue Dec 05, 2017 5:34 pm
Hi and thanks for the answer.
I have tried all of the above, but just one adapter. The entry for ethernet is not included in this phones config.
Hope your tech. staff can fix it. The USB ports on this adapter works as they should.
Regards
Tue Dec 05, 2017 6:33 pm
Regards
Thanks for letting us know!
Mon Dec 11, 2017 10:48 pm
Sorry but this feature can't be implemented at the moment.
