macevedo
[SOLVED] No command, volume not working,
Tue Nov 28, 2017 8:16 pm
I bought this BV8000 pro on September (2 months ago), on the weekend my phone fell down from the chair and have a knock on the floor.
The announcent say that this is a "rugged phone", so what happen? why could't resist a little fall down like this.
In this moment my phone looks like the picture and I dont know what can I do? I really like it a lot. Wich is the warranty of my phone? Could you make fix it? Could you help me please?
Re: No command, volume not working,
Tue Nov 28, 2017 9:14 pm
Sorry to hear this.
You can try to:
- press Power and Volume-up together. you should come to recovery mode. Select and choose reboot. Your phone should start normal.
- if that don't help maybe a hardware button on the side is canted. you can remove the screws on the side and check the buttons.
Rugged_DOC
Wed Nov 29, 2017 2:40 pm
As i can see, the "VOL +" button knocked on the floor and got stuck (or the side metal frame got deformed and pushes the vol + button). Just remove the side screws with a torx screwdriver, remove the side metal frame, check if the microswitch underneath works and reassembly everything.
Easy fix! ;)
The "no command" screen shows because VOL + button acts as it is always pressed during boot.
macevedo
Re: [SOLVED] No command, volume not working,
Mon Dec 04, 2017 8:09 pm
I'm going to try.
So another question, which is the warranty for this cellphone? What covers?
thank for your comments!
Mariana
Tue Dec 05, 2017 12:32 pm
macevedo wrote:
I'm going to try.
Mariana
You will have to contact your seller to get these infos, but i can tell you that user damage is usually not covered by warranty... and it happens for EVERY brand or good.
tysken
Sat Dec 16, 2017 5:28 pm
can you tell us were you live?
is the gravity so strong that this damage happens by falling from the chair?
A rugged phone is The BV8000 Pro, but damages by user, not even a steel alloy phone would survive.Be more happy you had not a other brand, would be destroyed totally...lol.
You get spare parts by contacting Blackview.They wil lnot be for free, but you get it, i believe.Contact them and be happy.
