freeauge
Can switch on the telephone P2 no more
Mon Nov 27, 2017 2:04 pm
I had turned the telephone off.
I cannot switch it on on the next day.
Have tried Recovery mode.
Could sometimes select an option but start not.
The Menue had disappeared just again.
Had never problems.
About every help I would be grateful.
(Ich hatte das Telefon ausgeschaltet.
Am nächsten Tag kann ich es nicht einschalten.
Habe Recovery-Modus versucht.
Konnte manchmal eine Option auswählen, aber nicht starten.
Das Menue war gleich wieder verschwunden.
Hatte noch nie Probleme.
Über jede Hilfe wäre ich dankbar.)
Re: Can switch on the telephone P2 no more
Mon Nov 27, 2017 4:49 pm
Had never problems.
Hello freeauge,
let us try two things first.
First of all, keep the ON/OFF button pressed for 20-25 seconds while connected via USB cable to your PC. Open a Explorer Window to see if it appears.
Then try to switch it on by releasing the button and pressing it again for 3-4 seconds. That executes a kind of hard-shutdown.
Second, if first option does not work, wipe data/factory reset in recovery:
- be sure that the little arrow points on recovery (select with volume up, enter with volume down)
- Then the open android with red triangle+"no command" is shown press Power and Volume up together again shortly
- wipe cache partition
In case this also does not lead to success you can try then to also
- wipe data/factory reset
But please note that your data and settings would get lost.
Hoffe, es klappt.
freeauge
Tue Nov 28, 2017 12:20 pm
Thank.
Has opened
Hat geklappt.
Tue Nov 28, 2017 12:49 pm
freeauge wrote:
Thank.
Has opened
Hat geklappt.
Great, happy to hear that you can use your mobile now again.
Freut mich, dass es wieder funktioniert.
