Don Harry
20170803_20171114-1146
Sun Nov 26, 2017 4:37 pm
OTA Update: 20170803_20171114-1146
Bluetooth still not proper working
Aeron
Re: 20170803_20171114-1146
Sun Nov 26, 2017 5:39 pm
I'm under 20171011 and my phone doesn't find OTA.
jman0
Mon Nov 27, 2017 12:19 pm
Neither does mine
mac3000
Mon Nov 27, 2017 1:45 pm
My updated, but it doesn't solve battery drainage problem and moment ago it restarts itself.
Mon Nov 27, 2017 3:05 pm
Still now I received no release note or flashing file but when you already received the OTA update remember that some issues may only be solved if you perform a wipe/factory reset after updating.
Netsplitz
Tue Nov 28, 2017 2:15 am
I don't see the OTA - running 20170803_20171011-929
mac3000
Tue Nov 28, 2017 7:09 am
I cannot do wipe/factory reset when I start phone using volume up and power there is only "No command" message.
jman0
Tue Nov 28, 2017 7:25 am
@blackview_admin any chance you could upload the new update as a Flash Tool flashable package, for those of us still not receiving the OTA notification?
AceRaven
Tue Nov 28, 2017 8:12 am
Is the problem with pressing twice Recent Apps button fixed? On BV8000Pro_blackview_20171011 you have to press it twice to if you're in any app or once if you're on home screen. I flashed BV8000Pro_blackview_20170829 because it was so annoying. When it will be possible to bind SOS button to any application?
dasiro
Wed Nov 29, 2017 9:41 am
I just bought it a few days ago and updated directly to this build.
For some reason I can't seem to get my office365 account added in the accounts menu. While adding it on port 993 with SSL/TLS and server outlook.office365.com it just can't make a connection to the server. Switching to port 443 always crashes the mail app
as a workaround I installed the outlook app, but that's horrible.
secondly: coming from a samsung device I had the option to define peak schedules to push mails and outside the peak schedule to sync manually. In the Blackview settings this functionality is apparently not available, causing my mails to come in at night, waking up about everyone in the building :p
