cientistagyn
[SOLVED] No HDR in the main camera
Sun Nov 26, 2017 5:48 am
I notice that my BV8000 pro does not have HDR in the main (back) camera , only the front camera.
How can i enable it or the main camera really don't have HDR ? I can't find it
Thank you
Rugged_DOC
Re: No HDR in the main camera
Sun Nov 26, 2017 12:53 pm
Hi! Android stock camera app lacks this function.
Use Opencamera app instead. It will work smooth! ;)
cientistagyn
Sun Nov 26, 2017 8:19 pm
The other BV8000 pro i bought to my son has the HDR in the main camera.
The build of my phone is v0.1_20170803. I can't update because seems i'm actually in the least version of my model
My son's version is different.
I want to enable HDR in my main camera. Can somebody help me ?
Thank you
Aeron
Sun Nov 26, 2017 8:54 pm
Same here, I don't have HDR on the main camera, but I can enable it on front camera.
Tue Nov 28, 2017 6:34 am
Have you tried any other camera apps?
jman0
Tue Nov 28, 2017 7:20 am
Other camera apps that have hdr work, but that's not the point.I think it should be the other way around, from camera doesn't really need hdr, but back camera does.
Moreover, the stock camera app is the only one that works to take photos with the dedicated camera button
Tue Nov 28, 2017 9:19 pm
you can set the camera button to work with other apps.
jman0
Wed Nov 29, 2017 9:07 am
Yes, you can long press the button to make it open another camera app installed, but once inside that other camera app, the button won't work to take photos, unless that app includes a setting to setup a specific button to take photos.
Anyway, what's the point in having hdr for front camera, but not for back camera?
Aeron
Wed Nov 29, 2017 10:37 am
I don't use the BV8000 Pro. The hardware is ok, but the software makes it an unfinished product.
Instead of releasing a new phone every 2 days, just fix the bugs of your existing phones and apply AOSP security fixes.
You would have a lot more of happy customers.
Rugged_DOC
Wed Nov 29, 2017 11:04 am
If using Open camera, wich is free , you can push the volume buttons to focus and/or take a photo. Just try it and you will be satisfied! ;)
Stock camera app is very limited, but is google's fault!
