ameerah
[SOLVED] I want to resolve my phone urgent after update
Sat Nov 25, 2017 7:32 pm
Request urgent solution
My phone system has changed today, and after that I changed the mode of light to night. Then the screen turned darker. I could not set up the settings or turn off the phone. Note that the sound still works, and when I touch the screen some applications are running but I can not see them.
My phone BV 800
Re: I want to resolve my phone urgent after update
Wed Nov 29, 2017 4:13 pm
what update did you make and how? What light setting did you change exactly?
Rugged_DOC
Wed Nov 29, 2017 10:31 pm
We can't understand your problem properly, but a factory reset should fix the problem considering that it happened after interacting with some settings. Let us know.
ameerah
Thu Nov 30, 2017 6:15 am
I have prepared factory settings. The update already mentioned can update the Android system
Thu Nov 30, 2017 10:19 am
Did the factory reset fix your problem?
