tysken
[User sharing] Discussion about features of the BV9000 Pro
Sat Nov 25, 2017 1:41 pm
Hello, i will give Blackview the chance to buy the new "flagship".
Before i need some information, have watched some You-tube Videos, but not all give me the exactly answer.
1. did it comes with the notification led?
2.Need it as the BV 6000 and the 8000 the longer usb-cable?
3.Need it a longer jack as well, so i can´t use it to connect to the radio by aux?
4.Battery looks to small for this big display, will it come with a bigger battery in future?
5.If i buy, how long is the warranty?
6.online update as well?
7. comes it with 6GB + 128 or only with 6GB+64?
I get the offer from Fanny Liu, and if it will be better then the BV8000 pro, i will get a owner of it.
Greetings from Sweden/Mathias
tysken
Re: all features of the BV9000 Pro
Fri Dec 01, 2017 6:48 pm
nobody is interesting in answering, so i do it to answer to myself lol.
1. yes it have notification led
2.i can´t check because i didn´t get it now, but i guess it is same way like the BV8000
3.i can´t check because i didn´t get it now, but i guess it is same way like the BV8000
4.i guess not, but it will be better to have the battery more bigger, the display will need some amperes.lol.
5.Warranty is about 6month trough Aliexpress, you can buy "extra" a warranty for 999! Dollars, i believe it´s a joke.But i didn´t find the real answer.
tmsjaeger1
Wed Jan 03, 2018 9:19 am
Any News on the audio jack or the USB port?
Thanks
Thomas
Santheluc
Device is not certified by Google
Mon Jan 08, 2018 10:50 pm
Hello, I just acquired a "blackview 9000 pro" but when I want to configure it is written:
"Device is not certified by Google"
my phone is unusable
tysken
Tue Jan 09, 2018 9:28 pm
Hello Thomas,
I don't know but my 9000pro is on the way. Then I will tell you.
Please have patience. Like me.
tysken
Fri Jan 19, 2018 10:28 pm
Thanks
Thomas
Hello Thomas,
i get it today and i can tell you the audio jack is connected by the USB port.It follows a adapter cable.
USB port i s type C and the same like the BV8000.
With the phone it follows the OTA cable, a adapter from C to micro USB, the key to open the simcard inset, a Gimmick, a Ring that you can stick on the back and it works as a tripod.
And remember, you need a 2 Amps charger otherwise you can´t charge it.The same charger follows as with the BV8000.
Disappointing i am on the fact, that you can´t use the SD-Card and two sim-cards same time.Only two sim-cards or one sim-card and the Sd-card.
The camera makes good pictures, the display is very clear in colors.So long i have not tested.What i like is the SOS button you can change the function of it.3 different apps or actions you can use by push the button one, twice or three times.
The sound is loud and clear.
LED notification is working, and the memory (128GB) is more then enough.But as i said, i would like insert a SD-Card with my music.The BV 9000 pro accept my 512 GB SD card, but i would use it with two sim cards....If there are some solutions, you are welcome.Read you can cut your simcard, so she fits upon the SD-card.But not sure.
Hopefully it will work better as the BV 8000 or the BV 6000.The BV 6000 get a new Display(get it from Alston, Blackview Service team), the BV 8000 had a bad microphone and i order the backside(you can order it in Aliexpress). And now it´s the USB-Port that has loose connection.I can only charge in a way to keep the cable in a special position.I hope the BV9000 Pro has not this malfunction in future.
With the Battery i think i will survive one day, i use often the mobile internet, Bluetooth and have the screen many times on.This costs energy.
I will continue with news, after i have tested it.So long it´s a great phone, and updates i do only if they are stable.
Greetings Mathias
Re: Device is not certified by Google
Mon Jan 22, 2018 8:29 pm
This can be solved by a simple Firmware update Over the Air (Wifi)
