chrisgo
[SOLVED] Allow buttons not working
Fri Nov 24, 2017 1:42 am
Hello all. I just brought a new BV8000 pro and am having an issue with the Allow selection to allow access for apps etc. For example i wish to add the weather-zone widget to my screen in nova launcher, however when it comes to giving it permissions a press allow but nothing happens and i have to press deny to exit. Any Ideas what could be causing this? Oh and it also happened before i installed nova launcher, so it is happening with ALL launchers. Thank for any help. it is much appreciated. Chris
Re: Allow buttons not working
Fri Nov 24, 2017 11:15 am
Check if you have any sceen overlay apps active (like for light dimming at night).
If nothing helps you could try to install the latest firmware and perform a wipe/factory reset*
* wipe data/factory reset in recovery (this will delete your data/settings):
chrisgo
Fri Nov 24, 2017 1:25 pm
Admin your bloods worth bottling.
A Factory reset was a pain in the butt, however it fixed the issues i was having so all good.
Thank you for your advice and help, very much appreciated.
