Bacon
BV7000 fingerprint scanner issue
Thu Nov 23, 2017 1:41 am
Hi
Not had my BV for long, its been doing the job fairly well but my fingerprint scanner has stopped, at first it was an intermitant issue but then got worse until it stopped all together, checked the diagnostics and its does not seem to think it has the functionality at all. Tried resetting the handset but still nothing, anyone got any ideas? Or do I give in and contact the seller for return under warranty?
Cheers
Paul
Re: BV7000 fingerprint scanner issue
Thu Nov 23, 2017 5:04 pm
I know this issue as an software bug in early firmware versions. So you could try to update to the latest firmware ( viewtopic.php?f=188&t=201430 ) and perform a wipe/factory reset* after that.
* wipe data/factory reset in recovery (this will delete your data/settings):
