cwtheating
[SOLVED] Back button
Mon Nov 20, 2017 8:53 pm
Back button is very intermittent on my new BV8000 Pro. Sometimes needing 4 or 5 presses to respond. Menu and home button work fine every time
Re: Back button
Fri Dec 01, 2017 12:08 am
Just update you device on the latest firmware and after that perform a factory reset: if you device isn't defective, the problem will be solved. Otherwise you'll have to contact your seller for a replacement under warranty.
