Hood
Camera not great
Sun Nov 19, 2017 6:52 pm
I and my brother have BV6000 phones and he mentioned to me about the poor quality of the photos. It was something I had not really noticed as most of the ones I take are close ups. After he mentioned it however I took some pictures of objects further away and sure enough they were blurred.
I also have a BV6000S and I took a pic with the 6000 and then exactly the same with the 6000S, the difference is amazing, the 6000S is sharp and clear where the 6000 is blurred.
Why is this? The 6000 is supposed to be a 13MP camera and the 6000S only 8MP so it should be the other way about. Is it a software problem? If so can it be fixed?
Re: Camera not great
Thu Nov 23, 2017 9:16 am
Have you tried using another camera app? Such as open camera?
Edit: And do you use the latest firmware?
Hood
Thu Nov 23, 2017 8:11 pm
Yes we both tried Open Camera. I have the latest firmware my brother has older.
Hood
Thu Nov 30, 2017 4:15 pm
Here are two pictures taken at the same time, one with BV6000s first and then BV6000
Here are both again but I zoomed in on these images on my computer and took screenshots.
As you can see the BV6000S image is much more crisp and clear and also the colour seems much better.
How can this be when the Camera on the BV6000S is supposedly inferior?
sidsood
Wed Feb 07, 2018 8:27 pm
Most #Android smartphones, that are manufactured today produce a fake camera shutter sound when you click a picture. Getting rid of the camera shutter sound can be as easy as turning down the volume on some Android devices, whilst for others, especially the #Blackview #BV6000 #Androidsmartphone require a little more effort. Find out how to turn off the #camerashuttersound on your device
#BlackviewBV6000
#camerasound #shuttersound
https://dreamworks75.blogspot.com/2017/12/turn-off-camera-sound-Blackview-BV6000.html
