Huguettepopiette
[SOLVED] charge batteri very slow
Thu Nov 16, 2017 6:10 pm
My cell phone is charging 100 percent in 8 hours. How to solve this problem?
thanks in advance
Re: charge batteri very slow
Fri Nov 24, 2017 11:54 am
Use the latest firmware and only the original cable + Plug.
JessiM
Mon Nov 27, 2017 5:20 am
I also have the problems with the slow-charging battery. I have no current firmware because I do not get OTA. Here is my posting viewtopic.php?f=192&t=325992.
And I do not want to risk turning my phone into a brick if I change the firmware. What should I do?
And I'm using the original chargingcable.
Wed Nov 29, 2017 2:39 pm
-Be sure it is really slower than other bv8000pro
-Use original plug and maybe try out on other original cable.
-Wipe your data/settings*
-Flash the latest firmware
-If it don't help ask your seller for an exchange
*wipe data/factory reset in recovery (this will delete your data/settings):
Rugged_DOC
Wed Nov 29, 2017 2:50 pm
Be sure to use non only the original usb cable, but also the original charger or a charger that supports the quick charge feature (9V output at 2A).
