bwolfgang2017
[SOLVED] Bluethooth connection issure with Oral-B
Tue Nov 14, 2017 2:38 pm
I use a Oral-B with Bluetooth support but I cann't use it with my BV6000 and BV8000pro do you have any idea what could the problem , it seems that the hardware see the device but in the interaction with the software interface the connection is gone.
Regards
Peter
Re: Bluethooth connection issure with Oral-B
Sat Dec 02, 2017 12:29 pm
Follow this thread, last posts will fix your bluetooth problems.
viewtopic.php?f=191&t=333190
